Want To Buy Impeller for 2011 AR240 STBD 6AP-R1321-10-00
Jeff_F
Kennett Square, PA
Looking for an impeller for a 2011 AR240, starboard side, Yamaha PN 6AP-R1321-10-00.
Chewed one up and they are on backorder. I'm willing to buy a pair, or something aftermarket to get us going again.
@Jeff_F
If you can find a Solas Concorde YS-CD-13/19 for Starboard will work if you can locate one.
It will be close enough out of the box you may not notice a significant difference. I would guess your torque and acceleration will increase and you would loose 2 or 3 MPH on the top end. If you order on make sure you order extra cones and also the removal tool for them.
I’d be interested in the stock one. Seems like the easiest way to get back running is to do the STBD impeller and housing, then in the off season (when parts are available) do the other one. I’ll message you.
