ScarabMike
- Green Cove Springs, FL
Im planning on it when I change out my impeller on my 300. Soon!
Faith, can you confirm which impeller you have? Either the SRZ or SRX?Have you done this yet? This could possibley give more mph. Someone needs to try this and report the difference.
SRXFaith, can you confirm which impeller you have? Either the SRZ or SRX?
TIA
so you changed out your 161 mm impeller and wear ring for 159mm solas 14/19 and gained 5mph?!? So what's your top speed now?No. I just replaced mine with 159 mm. I got pitch 14/19. I also have the 195 HOI. I went with the steel wear ring and gained 5mph in speed.
So this is an old thread but I purchased the incorrect part due to reading post like this one. I purchased a 159mm ring for my 2014 scarab 195. The factory one is definitely a 161mm in my boat. So there goes $50. Maybe some people do have 159mm impellers idk. I suggest anyone buying a ring pop out the old one first and measure to make sure so you don’t make the mistake I did.All, this has been covered in here hundreds of times. The 250's have a 159mm impeller and wear ring. The Scarab site is incorrect.
