steve0617
- Littleton CO
- AR195
2019 AR195
So I removed the 4 14mm bolts exposing the cone (going to do the L13 replacement). But now how do I remove the pump/impeller/drive shaft? Practicing for when I need to do this during the summer.
It doesn't appear anything can detach and pull out after exposing the cone/pump strainer. And there's 5 more bolts against the transom. 4 big ones and 1 small one at about 9 o'clock (see pics).
Did I remove the wrong bolts for pulling the impeller/drive shaft?
Note the length of the 14mm bolts is much shorter than older boat's bolts. Reference is my 14mm deep socket for length.
