bobbie
- Georgetown, TX
- X
Okay, at least it's not deuterium from a nuclear reactor, lol.@swatski well...the Willamette River does have an issue with sewage spills. Maybe that's where the "heavy" water comes from
I know this is a very old thread but I just noticed something interesting. My fat sacs are connected to the ballast pumps through the top of the bag while yours are connected through the bottom. I like the idea of the bottom, as clearly that would be better to drain but I presumed mine came from the factory with the top connection. Also, has anyone put a quicker ballast pump in these boats?
Yes, I installed 4x jabsco Ballast king pumps, but I also added 1" intakes and 1" hoses, as others have done. I don't know how much improvement you'll get if you just replace the pump and leave everything else the same. Factory hoses are 3/4" and so is the intake.I know this is a very old thread but I just noticed something interesting. My fat sacs are connected to the ballast pumps through the top of the bag while yours are connected through the bottom. I like the idea of the bottom, as clearly that would be better to drain but I presumed mine came from the factory with the top connection. Also, has anyone put a quicker ballast pump in these boats?
This is a late reply, but I just saw it. You can bypass the timer, but you'll need to re-wire to do it. In factory config, the timer handles reversing polarity so the pump fills, or drains. If you remove the factory timer, you'll need to replace the rocker switch and re-wire it so the switch itself can reverse the polarity of the pump when needed. Wakemakers has pre-wired switches and the appropriate pump wire. If I were doing that, I'd probably pull the timer, wire, and switch, and replace, rather than rigging the wiring that is there, which could also be done. You can also add a wakemakers timer, which is easily adjustable for whatever fill times you want. That would be a good idea, as you'd still have some safeguards for your pump, and your boat.Anyone any advice on the switch situation?
Totally appreciate that a bespoke ballast bag system better than stock, BUT, stock bags OK for start. If I can bypass timer, that is.
The 3/4" is definitely limiting. I'm not saying you won't get SOME improvement, but I don't think it would be significant. Now that I think about, it would also require re-wiring, even just swapping the pump. The factory pump pulls 11.5a on either 14 or 16 gauge wire. The ballast king that I installed, which is what you would do I assume (it's the fastest reversible pump available right now) pulls 19a and requires 12ga wire. So you would have a fair amount of effort, and a new timer, and a new switch. I don't think the juice would be worth the squeeze.Has anyone just swapped out the pump for a faster pump? or are the 3/4" hoses truly the limiting factor? I don't want to rework the entire boat.
3/4 to 1” is almost double the area!For the record, forgive my comment about about the fill location on my ballast. It is at the bottom, I had the bag out of the boat as I blew out a fitting last year and was thinking of my secondary bag I use on the swim platform.
Has anyone just swapped out the pump for a faster pump? or are the 3/4" hoses truly the limiting factor? I don't want to rework the entire boat, as I think next year I may look at swapping boats but if I can get something a bit faster to fill/empty the bags this year I would probably do it.
I am not sure about the 212X but on my SX230 the floor that is in the under seat storage continues all the way back to the back of the upper swim step. It is hidden in the engine compartment by the plywood walls. The shelf is approximately 16 inches wide and 6 feet long.
This is a picture looking forward from a cup holder hole at the back left corner you can see the shelf in the bilge. The carpeted area is beside the engine. I plan to install 400 pound bags using about 3 feet of this area.
This is in the engine compartment with the plywood removed.
I'm mot sure how to remove the walls in the engine compartment but I'd beleive it's pretty straightforward, if you want access you can also remove the false wall in the under seat storage area, it's just held by a couple phillips self tapping screwshow did you remove that plywood??
