Beachbummer
- Houston TX
- SX
So...random thoughts...
I know the with key in Off position, and or with lanyard disconnected, there is some ground to each engine to turn it off if it's running... Any consequence to tapping into this ground with an indicator light to show when it's in this position, so if you have forgotten to engage the lanyard, you have indication prior to the engine not starting? Or if the switch fails, you can see the indicator that ground is being sent to engine to shut it off???
Any thoughts?
Thanks!
Any thoughts?
Thanks!
