Installing Fulton F2 Winch on MFI trailer.
Bruce
Royal, AR
I received a Fulton F2 Winch for Fathers Day to replace the factory Fulton winch on my MFI trailer. I replaced the strap on my factory winch last year but it has not locked correctly this year.
It is available for $77 shipped from http://www.zoro.com/i/G5113333/?category=5565 . My wife actually got it for $62 with a $15 off code found online. It is model # FW16000101.
This is a basic F2 without the multiple gears. It seems to be well made and well functioning winch. It is made from stainless and aluminum. I hope it will suffer less from rust than the factory winch.
My 7 year old daughter assembled the handle to the winch and my four year old helped attach it to the trailer. Both of them played tug a war while I winched in the strap. The total assembly time was less than 10 minutes and it could have been less than 5 if I was in a hurry. The bolts to attach it to the trailer are in an adjustable track allowing them to fit the factory hole pattern.
Here is a picture of it installed. The body is aluminum and the spool appears to be stainless. The locking handle and its mechanism are substantial and easy to use.
Great write up, Bruce. I have wanted a new winch, but I haven't ever done this. The only problem I have with the stock winch is that, sometimes, it is difficult to get the lock to engage to winch the boat back onto the trailer. Sometimes, you have to wiggle it around a few times to get that lock to engage.
Again, great write up and the install looks great!
@farrelltravis, the lock engagement issue is exactly why mine was replaced.
@Bruce great write up and thanks for pointing out what I need to do soon. I just replaced my strap this spring and now all of a sudden the "switch " on it is acting up. Should have waited a while longer for the whole thing to fail and do it at once... :)
I forgot to ask you.....where is the disco ball in the garage??? :D
Last year my daughter wanted to have a dance birthday party. I swapped the can lights for black lights and led disco balls. One set is still installed.
This one has my truck and the LX210 in it
Nice write up. I have the step up which is the Fulton F2 two speed. I haven't used the low gear much and probably would have been just fine with the model you have. I really like mine a lot. bowstopstep.jpg
The only thing I'm concerned about is some metal shavings I found inside mine when I popped the two screws off the plastic grate on the top. 13764248878141.jpg 13763689464751.jpg Posted that story on the other site and there really wasn't a conclusion. I'll take a look at it again at some point this year.
Also if you put the winch so the strap comes off the top of the housing wheel, then it can damage your roller as it did mine as seen in this picture.13763689103490.jpg
I installed an F2 two speed last weekend. I have used it 2 times so far and LOVE it! I got really tired of the stock winch not locking down. I was afraid it was going to fail on me going down the road. The F2 is actually overkill for what is needed, but it sure makes winching the boat onto the trailer super easy.
My only tip is that you will need a 15mm deep socket wrench to get to the bolts on the bottom. It took me a little while to figure out the size, so hopefully that will save someone some time.
Whoops! Added my comment to yours...
Here is mine :banghead:
That has to make it difficult to detail the boat...lol
HaHaHa, busted @Bruce. Are you still wearing those big collared shirts and bell bottoms?:winkingthumbsup" I installed the Fulton F2 two speed last year. It was a direct bolt on and made a big difference as I winch on & off with the UBB's. No more entertaining the folks at the ramp as I front flip over the bow to attach the winch while power loading.
Nice lights Bruce! Love it....the winches everyone has installed look great too! My time is coming for one......
I have the same fulton you do Bruce. Easy install, well worth the money for safety of covering the teeth. That is a great price too!
I changed out to the F2 wench and a Seasense polymer roller last year on my MFI trailer...both are excellent products!
Nice winch...and groovy lights in the garage! :winkingthumbsup"
Nice write up. I have the step up which is the Fulton F2 two speed. I haven't used the low gear much and probably would have been just fine with the model you have. I really like mine a lot. View attachment 7308
The only thing I'm concerned about is some metal shavings I found inside mine when I popped the two screws off the plastic grate on the top. View attachment 7279 View attachment 7280 Posted that story on the other site and there really wasn't a conclusion. I'll take a look at it again at some point this year.
Also if you put the winch so the strap comes off the top of the housing wheel, then it can damage your roller as it did mine as seen in this picture.View attachment 7281
Derek,
Any update on the metal shavings?
We are having a good season here...
You?
Eric
Derek,
You?
Eric
It has been an awesome season so far in SE MN. My winch is performing great. I don't think I have used the slow speed setting once. I will pop off the cap tonight and take a picture.
Which model is good for the AR230HO? The boat weighs about 3500# but the winch is for 1600#.
E
Here are some pictures of the inside of my winch. I still see metal shavings but the gears look good. I added a bunch of lithium grease to every contact point so hopefully it will give me many years of good service. This is the two speed version and I always use the slow crank mode.
