- Royal, AR
- SX
I chose to use a Johnson UltimaBilge™ 600 bilge pump for my second bilge pump and to install at the lowest point in the boat just in front of the drain plug. I wanted an automatic pump. Johnson and Rule pumps seem to have the best reviews. All bilge pumps seem to have a number of negative reviews. I chose the Johnson because our boats already have a Rule pump. I am hoping that if anything were to prevent one of the pumps from working the other will continue to work.
Before beginning installation I tested the pump in a dry bucket. Every time I added more than 3/4" of water it was pumped out. The pump turned itself on and off correctly
I had the water box loose from changing the scupper valve. I tied the water box to the port side and worked around it.
I ran wiring from the dash area then soldered and shrink tubed the connections. I used a double layer of shrink tubing to help keep water away from the electricity.
This is the first layer. One of the wires has a piece of shrink tubing closing it off. This third wire is used to manually activate the pump. I plan to let it run automatically.
And the second which is over the top of the first.
I decided to epoxy the pumps intake grate to the hull. I should be able to remove the pump in the future and replace it with the same model by separating the pump and intake grate.. If it is no longer available I will have the difficult process of removing the grate from the hull.
I vacuumed and then cleaned the hull area where I was going to install the pump with acetone.
I fully assembled the wiring and hose to the pump. I spread five minute epoxy on the bottom of the grate being careful not to drip any into the pump. Then I carefully placed the pump into its final position.
You can see part of the installed pump in this picture. The off white hose is the scupper. The bright white caulk is on the drain plug.
While the caulk was drying I drilled the hole for and installed the 3/4" thru hull fitting. I placed a small amount of Life Caulk between the thru hull fitting and the hull on the outside and on the last three threads. I accessed the area through the engine compartment with the plywood sidewall removed.
If I was not opening that sidewall for any other reason I would consider installing the drain near the floor drains and transducer exit. It would be more difficult to monitor there but much easier to install.
Here is a picture of the thru hull fitting installed from the inside. The clear pressure hose is connected to the new fitting.
This is a picture from the outside.
