MidnightRider
- Zumbro Falls, MN
- Malibu
- Wake
I did full interior and exterior LED install last year but never got around to documenting it. Thought I'd finally create a post for my install in case it is of interest to anyone. First a disclaimer, I spent way too much time and money on this install but had some ideas I wanted to try so I said what the hell and just went for it.
I wanted to do custom led lights and after searching for something I liked in the sizes I liked, I just couldn't find what I wanted so decided to make my own LED lights using LED mounting channels.
Some wants:
- Custom mounted LED
- RGB all around
- Underwater and exterior accent down lighting
- Multi-zone controller with music sync
I started putting together the vision with a Wet Sounds 4 Zone RGB LED Controller (WS-4Z-RGB). Not cheap, but pretty cool controller.
Has zone control as well as music synch (will post a video of the music synch later)
I made the decision to create an entire wiring harness for the whole system ahead of time so I could run the wiring one time and not have to figure out all the wire to pull for each zone/led branch. I split the zones into (1)"Floor", (2)"Mid", (3)"Tower", (4)"Underwater, Exterior Down Light"
The Wetsounds controller allows me to control each zone separately as far as the zone color and mode (flashing, multi color flash, strobe, etc).
Then I got into creating each light I needed. I cut all the sizes of led lights I needed and split the protective coating to wire in pig tails in the center of each strip. This would allow me to run the pig tail out the center of the LED channel for installation. After soldering in the pig tails I resealed it with silicone. I ended up with four different sized batches.
Next I got into cutting the LED channel down to the different sizes. I used the sliver channel for any LEDs that would install on white gel coat and black channel for any LEDs that would be installed on black gel coat/plastic. Drilled the holes for the screws and for the LED pig tail.
Channels were install in the various locations
The pre-fab'd wiring harness was run through out the boat and then started installing the LEDs into the channels
Lastly installed the channel lens and end caps
I also install an extra long one over head on the tower
EXTERIOR
I installed some down light LEDs along both sides of the boat
I also install a Dagon 5150 RGB underwater 8000 Lumen LED on the transom (no pics - video of it later).
RESULTS
On White it actually makes for a really nice courtesy lighting for cleaning up at the end of the night etc.
The exterior down lighting LEDs
Some wants:
- RGB all around
EXTERIOR
RESULTS
