Neutron
- New Bern, NC
I am working on a customers ar240 and i wanted to post this since there has been in the past inquiries about the subject.
This job started as a seized starboard pump and a failure to start port engine.
Boat is stored on a lift so the customer towed out and trailered to my house to work on.
Come to find out the engine compartment flooded into pirt air box. Port Engine filled with water not starboard (air box up higher)
First we assumed rain water with plug in and bilge pump inop.
Time was ticking so pump out water from engine, fill with oil, find problem with no start, turns out was a bad spot in lanyard.
Pulled both pumps and starboard fired right up.
Got port to start but sounded like a bag of marbles. Shut down and saw this
Intermediate bearing waisted, this is where bulk of water came from under slow tow to ramp.
Good news ladies and gents, it was not too bad to remove the housing.
Unbolted 4 motor mounts, marking each shim where it goes(all were same thickness anyway)
Loosened exhaust clamps and freed up hose, removed rear water inlet hose. And wiggled engine forward just enough to remove housing.
Not a bad job at all. Should be easy to reinstall.
Waiting for a few more parts to come in this week then i will press the new assembly together, rebuild the pumps and it should be good to go.
