Dfred
- Fairfax Virginia
Looking for help with definitions here. I cannot find anything in Yamaha literature or other places that may help us out.
We have a well-loved AR210, 2009 (that we can afford). Yamaha specs it at 21’ long…. Which may pose a problem as we embark on investing into a lake community that has the following rules. I am inclined to argue that the “direct drive” impeller jetboat is in-fact “mid-mounted engine” as defined in bullet 2, and ask for approval of our AR210. Or is this a hopeless case that forces us into a 190/195?:
“Maximum Power Watercraft Lengths:
• Tri-hulls, V-hulls, Flat Bottom, and Deck Boats with an outboard or an inboard/outboard engine, Inboard boats with a rear-mounted V-drive engine, and Jet-Drive boats will be limited in length to 20 feet 0 inches. Forward drive propulsion systems such as the Volvo Penta drive are classified as an inboard/outdrive which falls under the 20 feet 0 inches boat length limit.
• Inboard boats with a mid-mounted engine direct drive will be limited in length to 21 feet 0 inches.
• Pontoon boats will be limited in length to 24 feet 0 inches.”
