Ridesteady
- Austin, Texas
- SX
We’re pleased to announce an extra $100 off (our most ever) for JETBOATERS.NET members on any Ridesteady for Yamaha Speed Control system purchased through February 28, 2024. The discount has already been applied on the order page. Click “Buy Now” here: www.hydrophase.com/yamaha
This offer can be combined with our existing $100 back for install pics / info submission, for a total of $200 back. An email will be sent after your Ridesteady ships with the pictures and information we request. The deadline to submit the pictures / information will be extended to May 1, 2024.
To see pictures other Yamaha Ridesteady owners have submitted, click here: https://www.hydrophase.com/support/...d_cust_video_tid=All&field_cust_quote_tid=All
Note that there is limited stock available for this promotion, so it may end early.
What is “Ridesteady for Yamaha”?
Ridesteady is a speed control system (“cruise control”) that uses GPS satellites or engine RPM to keep your boat at the set speed you choose. On twin engine boats, it will also automatically synchronize your engines. There are many other features as well that can be viewed at www.hydrophase.com/yamaha
Why would I want this?
Yamaha jet boats, despite their many advantages, are difficult to keep at a precise speed. Ridesteady handles this for you automatically. It is particularly nice with water sports, but also beneficial for cruising. It allows the driver to focus on steering the boat safely, rather than fixating on the speedometer. Life is much more relaxing for both the driver and rider.
How difficult is it to install?
Ridesteady for Yamaha works directly with the throttle signal electronically, so no motors are needed to install. Light wiring work is required at the helm (tapping into the ignition switch wiring), as well as some “plug and play” operations on the engine side. A video of an install and the full installation manual can be viewed here: Install Guides & How-To Videos | HYDROPHASE LLC
How easy is it to use?
Ease-of-use was considered from the beginning of the design process. While there are many features, it is designed to work out of the box. The rotary knob makes changing set speed and settings quick and easy.
What Yamaha boats is Ridesteady compatible with?
2006-newer AR210, SX210, SR210
2010-newer AR240, SX240, 242 Limited
2012-newer AR190, SX190, 212SS, 212X
2013-newer AR192, SX192
2017-newer AR195, SX195, 212 Limited, 190FSH
2018-newer 210FSH
2020-newer 212S, 212, 195S, 195FSH
2021-newer AR250, SX250, 252S, 252FSH
2023-newer AR220, SX220, 222S, 222FSH, 220FSH
Do you have user videos?
@swatski has done an amazing job of capturing his first runs with Ridesteady.
https://jetboaters.net/threads/new-...nch-for-twins-ridesteady-by-hydrophase.12590/
Cruising with a 2013 Yamaha 242 Limited:
Surfing with Ridesteady behind a 2019 AR195:
Customer install on a 2014 242 Limited:
Customer install on a 2014 SX190:
Here is a "preview" video from 2017 showing Ridesteady for Yamaha in action on a 2006 SX210:
What is this new "Auto Launch" feature?
Another exclusive Ridesteady feature. More information here: https://www.hydrophase.com/yamaha/autolaunch
https://jetboaters.net/threads/new-auto-launch-feature-now-available-for-ridesteady-owners.40399/
Questions?
Email: info@hydrophase.com
Call: 512-524-8686
Or message @Ridesteady on JETBOATERS.NET
2018-newer 210FSH
Questions?
Call: 512-524-8686
