Issus with imprella
Daniel E
Glastron
GT
How to remove this part?
Jet Boat Tom
Northern Michigan
Glastron
GT
If you took the nuts off get a good grip on it and pull it straight out. Fyi no need to pull the nose cone off to remove pump.
Daniel E
Glastron
GT
we have tried but it is rock hard. I have a Glastron 187 is there Any difference to a seadoo.
Sidarousmg
Mechanicsville, VA
SeaDoo
Challenger
looks just like my seadoo challenger. the drive shaft is mated to this part via splines. are you removing because something got sucked up? if so, look from under the grate and see if something there, maybe something is providing additional resistance??
Daniel E
Glastron
GT
I remove the impeller sinne I lost the jet when I was driving. the engine triggers. So I think something is wrong with the shaft or impeller.
Winerocks
Bloomington, Indiana
HO Impulse
Tap on the housing very gently with a rubber mallet to break the seal.
