Keel Guard and the drain hole
smthng
Fruit Cove, FL 32259
A... stupid place for a drain.
B... I was just about to start prepping for my keel guard install when I noticed this. How's everyone else handling it? Razor blade the keel guard?
Billtex2000
Lake Wallenpaupack, PA
Just start right below it...No? Don't think it would need to be up that higho_O
itsdgm
I'd recommend starting the keel guard at or below the waterline. On my boat (going from memory) that would be down around the second chine. Or is it the third? Anyway, I think my drain is higher than yours.
smthng
I decided to give Megaware a call and get their thoughts on it... They don't know my boat exactly, but said I should start below the drain as long as the keelguard is at least six inches above the water line. They said the issue (particularly with jet boats) is that if the front of the guard catches the water, the water will eventually work it's way under it and rip it off. As long as it's at least six inches above the waterline, it shouldn't be an issue.
So, if anyone has an 08-10 212 in the water, I'd appreciate it if they could see how high that drain is above the water line... or better yet, post a picture of it for me. :)
Oh... they also said cutting it is a bad, bad idea. :S
ToddW850
Destin, Florida
Yes, start below it. I can take a pic of mine when I get home if needed.
McMark
Monongahela, PA
15" from the bottom of the bow hook puts mine just under the waterline at rest. On a 2015 ar240.
ToddW850
Destin, Florida
Mine was installed by the previous owner. Found a pic on my phone.
smthng
Thanks! That's what I figured, it's just nice to be sure before scuffing up gel coat.
buckbuck
Texas
I think mine is like ToddW850. Maybe a bit lower. I have not had any problem with it coming loose and beach, bounce off submerged trees and run really skinny water all the time.
Ronnie
SF Bay Area
I have installed it both ways , that is above and below the anchor compartments drain. When above it I used a small hole saw to make an opening large enough to accommodate the drain/though hull fitting. The hardest part of doing this is making sure the hole, which was drilled on a bench, lined up with the though hull fitting when the keel guard was installed. That stated, I'd just install it below the drain unless I was worried more about what might hit the bow than keel.
jawsf16
Just below the drain on my 08 sx210 which is the same hull. I would have mounted it slightly lower if going today. More like the pic above. Don't overthink it.
CrankyGypsy
Tampa, FL 33615
SeaDoo
Challenger
mine starts just below the drain. keep in mind KeelShield recommends the front edge be 9" above the water line. that doesn't mean measuring 9" of keel (at an angle) - it means you measure straight up, perpendicular from the water (making the keel distance greater than 9"). but that's being anal ...like jaws said, don't overthink it.
