daaaddy27
- FSH Sport
I'm doing it!! I'm mounting my transducer on the keel!
I've always felt like this is the optimal place for a transducer for sidescan and I was trying to think of how I can pull it off. I decided to melt a small cutting board (HDPE which I believe is the same as starboard???) at 400 deg F for a little over an hour and then molded it to the keel. To keep it from sticking I sprayed cooking oil on keel. At the base I used a trowel, which helped create a flat surface that I will attach my transducer to. After a couple minutes the plastic was cooling, and wasn't moving as much, so I threw it in some cold water to cool it down and solidify the mold. Here's where I'm at in the process. It looks like crap but I'm like, whatever because it will be in the water.
Next step is to trim some of the excess plastic, fill in the gaps with JB weld epoxy, then sand everything down to make it look halfway decent.
