blthlt
- Charlotte NC
- Scarab
- 255 ID
300 RMS 600 Peak I believe.
at 2 ohms?300 RMS 600 Peak I believe.
perfect. I will just order that. might need some help on wireing that up. what gauge of power wire would you use, 4 or 8?It's either a dual 4 ohm or dual 2 ohm sub. I'll have to pull it out to tell. I can do that this afternoon. That amp isnt marine grade, that'd be my only gripe; though at it's cost you could replace one every other year and do that for several years and not be out of pocket as much as some name brand marine grade amps are. If keeping the 1 original sub with no upgrades or additions I would probably use this amp in my setup. Rockville DBM25 1400 Watt 2 Channel Marine/Boat Amplifier Amp w/Silicone Covers
Figure the max amperage you will draw and how long the wire will be. Then you can use this chart to determine the gauge size needed. If in doubt, go larger (smaller number) guage.also would you wire the rockville amp with 4 ga or 8?
