dan144k
- Palatine, IL
Thanks Cam
Your PLC system with level controls looks great.
I was thinking the 1-1/4" intake was the route to go, and if I have room in my pump assembly may try and make room for a 4th for future while down in the boat. I may try and use a Banjo (Heavy Duty Polypropylene Full Flow Ball Valve) so I can bolt things together easier in the boat after pre-assembly of piping. I know bronze is recommended for thru-hull fittings.
I thought of putting a PLC in (I have access to and programming help available) I am gonna go cheap and simple with fill/drain switches.
Also considered bluetooth or wifi relay board and phone or tablet controls system.
I remember reading the aerator pumps don't burn up as quickly from running dry like the reversible pumps.
