FLJetBoater
- 242 Limited S E-Series
Is it possible, or what could cause, only one of the engines to crank and not start?
As I’m sweating my ass of trying to fix our old boat my daughter was out on our new one. She calls me and says stbd engine won’t start. She started port, no problem. Crank stbd 4-5 times, no start. I tell her to pull the lanyard and reseat it as it’s the only thing that comes to mind for crank/no start. both start up no problem and I don’t hear from her for the rest of the day. When she gets home she said it did it again. But she only cranked it once then reseat the lanyard and it started right up.
Is it even possible that the kill switch could only affect one engine like that? I verified after that the kill switch does kill both engines. And both started fine on the trailer after she got back.
Thoughts?
Edit: it’s a 2015 242 LS
Thoughts?
