biffdotorg
- Pelican Rapids, MN
- Limited S
I don’t have that slack in my belt after trailering. I crank it up as snug as I can get it and it stays there. Do you think yours is due to the really steep ramps and cranking it is just difficult to make it snug? I’m not debating you. I’m just curious if I should try it. Maybe it will ride even better than I have it now.
This has been a common discussion on this page is the winch post. They are crap on these trailers and many have actually welded there winch post for extra support. We have all found our transom straps loose, and it has nothing to do with how tight you winch it down. It has to do with the amount the winch post gives.
Do a quick search on here for "welded winch post" and you will find this is very common.
