paratrooper39
- San Diego, CA
Rings:
https://www.amazon.com/s/ref=nb_sb_noss_2/146-3841079-7746554?url=search-alias=aps&field-keywords=LED+speaker+rings
Wire (RGB)
https://www.amazon.com/EvZ-Color-Extension-Cable-Strip/dp/B00DPQMKBS/ref=pd_sim_107_3?_encoding=UTF8&pd_rd_i=B00DPQMKBS&pd_rd_r=7KQGQ282GSKFAF3Q76ND&pd_rd_w=hHbTt&pd_rd_wg=enE8H&psc=1&refRID=7KQGQ282GSKFAF3Q76ND
You will also need an RGB controller, also found on amazon but many choices.
Yep, was pretty darn simple. The only issue is that you need to wire a loop around the boat from speaker to speaker and then determine how you want the lights to come on. I powered mine off of the switch normally used for the small light by the throttle, and I no longer use that light. I didn't want a static white light by the throttles while running different colored lights.
Wire (RGB)
