GiddYupJoe
- Beavercreek, Ohio
- Boatless
- NA
- X
- NA
I just had my lift modified to accommodate my new 242 limited. I asked the lift guy if I could back in or not and he said its one or the other but not both. He said he would have to modify the placement of the float things if I wanted to back in. My lift is a 6800 lb lift, so weight should not be a problem.
So my question for you is...have you specifically had your float things setup for backing in? Or was my lift guy just looking for a few more bucks?
Thanks!!!
I have no clue. He is spacing out my bunks this week. I didn't now there was a difference?? Nor did we even talk about me backing in. I just assumed I would pull in normal until I got to chatting with all of you! I am not going to bug him at this point, I'm just glad I have a place to put it. If I can back in then great, if not OH well! It will prolly be to late but after I get down there on Sunday (pending weather) I will give it a try and let you know the results. At least you will know if the guy is BS or not. Or it may be specific to the type of lift??
