Looking for part number - table mount bracket
soundshark
Long Island NY
I have a 19' without table mount. I would really like to add one and love the design of the vertical slide-in mount of the 24's.
Here is a picture of what I'm looking for, and the part number I think it is but it's so hard to figure it out from the factory diagrams. Any tips welcome.
F3H-U4825-10-00 ???
Billtex2000
Lake Wallenpaupack, PA
Bracket, Table
F3H-U4825-10-00
Spacer 1
F3H-U471E-00-00
Screw, Countersunk
90151-14S24-00 (X8)
Washer, Plate
90201-14S00-00 (X8)
Nut, Self-Locking
90185-14S00-00 (X8)
I presume you're putting it on your 190 so you'll need the hardware and spacer too.
DBamaC
Hoover, Al
AR192
F3H-U4825-10-00 ???
If you are going to put the table mount on the swim beck, plan on putting support behind the fiberglass. It is thinner than you think. I'm not using mine yet until I get the extra support installed.
soundshark
Long Island NY
Hm, I was worried about this. How did they solve it on the 240? Is it that much thicker?
DBamaC
Hoover, Al
AR192
I'm not sure. Once the boating season is over, I plan to just cut a rectangle of aluminum, drill holes using the table mount as a template and reinstall. I think that will give it ample support. I attached a pic to show where mine is mounted. Also, this was mounted before I bought the boat by the guys at Jet Boat Pilot. I'm assuming this is the best place as they are some of our experts on these boats. We may have a member that mounted it somewhere else and had more luck. The one mounted inside the cockpit is rock solid. I don't think I have a pic that shows where it is. I can take one if you need it.
