TXtraumaRN
- Houston
- 195S
I'm trying to set up an audio system on my 2022 195s while keeping the Connext system. Everything is being run off the remote head unit on the transom. Original plan was to run the JBL towers and Kicker sub off of a JBL 1800 watt Amp, but I'm just not getting the sound I'm looking for. The towers sound flat and I'm barely getting any bass from the sub. Is the amp too small to run both? Now I'm thinking about maybe running only the towers (bridged) off the JBL Amp, and running a separate Amp for the sub. I feel like this Amp should be more than enough for both though? Is the amp too big for only the towers? Should I do the opposite and run a different Amp for the towers and run the sub off the JBL? I've read good reviews on the sub when pushing close to 1000w. Maybe a mono block Amp for the sub? Also settings on both? Bridged? Recommended Freq? Any help would be greatly appreciated.
Second... Recommendation on another Amp (if needed)?
The cabin speakers are running off a separate 400w JBL Amp, and I'm happy with that setup. Below are the specs on what I currently have to work with.
KICKER 46CWTB104
10 Inch Subwoofer
400W RMS with 800W Peak Power
4 Ohm
Enclosed Tube https://www.amazon.com/dp/B07N95Q15K/ref=cm_sw_r_apan_glt_i_M7NT3CB0FRP1F99ZZS4T
JBL dual 8" Towers X Marine MT8HLB
General Specifications
Power Handling150Wrms, 450W peak
Sensitivity (@ 2.83V)92dB
Frequency Response40Hz – 20kHz
Voice Coil Diameter1.5in. (38.5mm)
Impedance4ohms
www.jbl.com
JBL MARINE MA4505 Amplifier
Max Power1800W Peak
RMS Power @ 2Ω (sub) 500W x 1, <1% THD+N
RMS Power @ 4Ω (sub)320W x 1, <1% THD+N
RMS Power @ 2Ω (full)65W x 4, <1% THD+N
RMS Power @ 4Ω (full)45W x 4, <1% THD+N
RMS Power @ 4Ω Bridged (full)130W x 2, <1% THD+N
Signal-to-Noise Ratio (sub)>80dB (ref 1W output @ 4Ω)
Signal-to-Noise Ratio (full-range)>80dB (ref 1W output @ 4Ω)
www.harmanaudio.com
KICKER 46CWTB104
10 Inch Subwoofer
4 Ohm
Impedance4ohms
JBL Tower X Marine MT8HLB | 8" (200mm) enclosed two-way marine audio tower speaker with 1" (25mm) horn loaded compression tweeter – Black
The JBL Tower X Marine Speaker system is ready to take your next outdoor adventure to the next level. The fully marinized speakers deliver a JBL pro sound experience complete with RGB lighting to bring it to life.
![www.jbl.com](https://www.jbl.com/on/demandware.static/Sites-JB-US-Site/-/default/dw19168f16/images/favicons/favicon-196x196.png)
Max Power1800W Peak
JBL Marine MA4505 | Multi-element high-performance, 5-channel amplifier
New weather-resistant & high-performance JBL Marine amplifiers deliver impressive power from a compact chassis designed to withstand outdoor environments.
![www.harmanaudio.com](https://www.harmanaudio.com/on/demandware.static/Sites-HA-US-Site/-/default/dw31b9f5ba/images/favicons/favicon-196x196.png)
