jocolo21
- Orlando Fl
- 252SE
So i purchased an Simrad GO XSE5 with total scan and i wanted a flush mount, meaning i wanted to look like it came installed on the boat, no extra brackets etc. Brand new on ebay for $350.
Needed for the install
painters tape
jigsaw with a bit to cut plastic/fiberglass
A flat file
lots of patience
I mock up the area and used the paimters tape to mark where to cut, make sure there is no cables or wires running behind.
drill a hole in one of the corners to be able to insert the blade , and start cutting. the cutting part is not hard and goes pretty quick with the right blade, it is better to cut a little tight and the file as needed..
Insert the unit into the holes with the provided gaskets and tighten the nut included.
The unit itself has an on/off button so you can find a power source to feed it or what i did, which i plug it using the auxiliary cable in the back. the cable has a cap so i pulled the plugs from the cap and inserted the + and - connectors from the unit and made it into a plug. Pretty simple. no need to splice up the wires..
