ncnmra
- Ontario, Canada
- X
I'm surprised that I couldn't find any reference to this issue. I have a 2008 212X and the captains seat has been loose from when I got it. The point where it is loose is the bottom post, where it enters the pedestal ring which attaches to the floor. The ring on the floor is solidly attached.
I took the bolts out to get the ring off, expecting there to be a nut or something to tighten, but was surprised that the pedestal post is only held in place by a lip around it. I'm assuming that it is designed such that the floor pressing up on it is supposed to keep it flush against the ring to prevent it from moving? In my case, it appears that it has "rubbed off" parts of the floor. The seat actually freely rotates at that spot. I thought originally that was by design, but I see now that there is a knob to adjust the rotation.
Has anyone seen or fixed this? I'm tempted to drill some holes through the ring/post and put some nuts/bolts through it to lock it in place. I think that ideally it should be welded, but I don't have the skills/equipment for that.
Additionally, does anyone know what the bolt in the last picture is for? I found it under the seat when I took it out. I think it is from the center of the post somewhere?
