nbontempi
Hey everyone, new to the forum. I have a 2006 Yamaha AR210. This is my second season with the boat and from what I can tell the boat was very well maintained before me. The other day I was out and suddenly lost power in both engines top end. Both engines top out at 7k RPM and about 15-20mph. I changed the plugs, gapped them correctly and it's the same. My port engine reached 8k RPM but still seemed to be struggling and the starboard engine is still at 7k max. When driving it will sporadicly jump to higher rpms for no more than a second or sound like its getting better then go back to 7k. Oil level is good. air filters are clean. No cavitation from what I can see without removing the pumps. Throttle cables seem to be adjusted properly and working. The owner before me mentioned that the ignition coil wires had issues at one point but that doesn't explain why both engines lost power at the same time. The only thing I can think of is clogged fuel pump filter? Any insight would be greatly appreciated! Thanks in advance!
