Lost Keys -easy solution?
Bdog
Twin Cities, MN
AR195
So at one point between the boat ramp and home my wife ended up removing the keys from the ignition for some reason I personally have always left them in unless we are docked overnight. Regardless the key probably flew away (with my amazing jetboaters.net floater on it) or blew out of the boat and I’m wondering since I have no other keys is there a site that offers replacement keys? How do I know which one is correct for me or would it just be easier to call the dealer?
captainhook
Southern Maryland
Limited
There is a number on my keys and I've found replacements all over, particularly eBay. If you don't have the key that doesn't help but it might be labeled on the ignition somewhere.
WilCo
It’s on the ignition. Remove the rubber over it. Loosen the nut holding it to dash and look for number on the silver.
sunbyrned
Louisville, KY
There's a thread in the FAQ regarding this and how to do what @WilCo is suggesting.
Bdog
Twin Cities, MN
AR195
I appreciate the help I think I’m getting closer I don’t see a rubber cover behind the helm 391D2AFC-81F4-4146-802F-6BCB48277853.jpeganywhere I did snap a pic I can read a few numbers on the ignition panel itself but I’m not sure what three numbers I am looking for?
jameskeller76
Georgetown, TX
Just recently ordered a spare set just in case something like this happens. Glad you had the paperwork!
Scottintexas
Corinth, TX (DFW)
I appreciate the help I think I’m getting closer I don’t see a rubber cover behind the helm anywhere I did snap a pic I can read a few numbers on the ignition panel itself but I’m not sure what three numbers I am looking for?
Glad you had it written down, for future reference I think he meant take the rubber boot/nut off the front of the key switch and that will allow you to remove the back portion behind the helm and read the key number,
marmstufl
Tampa Bay, Fl
Make sure your keys are attached to a solid key ring. Few months ago I docked my boat.. as I was putting my keys in my pocket the ring broke mid step and I kicked one keys in the water. Thank God I was able to catch the other one.
Limped home on one engine and learned a value lesson on key ring maintenance and having spares. :D
sunbyrned
Louisville, KY
That's good advice actually. Was yours a beaded chain?
marmstufl
Tampa Bay, Fl
Yeah, it was a beaded chain.. a very old one. Honestly it was my fault for being lazy about it. I was cursing the heavens when it happened, like "I cannot believe out of all the things on this boat to go wrong... the frigging key chain..."
sunbyrned
Louisville, KY
Mine are on one of those. Time to switch over to a solid ring. Thanks!
Bdog
Twin Cities, MN
AR195
Here’s a good solid ring I found on Amazon they are big which I don’t mind harder to lose.
Once I found the number in my paperwork I proceeded to order six keys should never have a problem again .
Beachbummer
Houston TX
A good specialized locksmith can make a copy of a key for less that $5. Late for the OP, but a good reminder that they are harder to replace once lost. Don't wait until then to get copies made. I keep a set hidden on the boat (won't tell you where :) ) in case I need them. Cheap insurance that has already saved a few trips.
Matt Phillips
Lake Tahoe
I keep a spare on my household keyring, and a spare in the tow vehicle. That way the fastest I have to go is back to the truck.
sunbyrned
Louisville, KY
Yep! I have a set hidden in the boat too in case I lose them on the water somehow.
Ratket
Lake Havasu City Arizona 86406
Beachbummer
Houston TX
So, two weekends ago our car keys fell in the Marina... The bottom is about 7ft deep, the water is murky, and the bottom soft mud. After trying with a net for a long time we gave up and tried later with a big pick up magnet from home Depot and we were able to find them. It took a long time, I thought they were gone.
No lesson here, floats are too big for those keys. We got lucky. Just don't drop them and everything will be ok.
Gym
Falmouth, MA (Cape Cod)
Well duh, Found this in the paperwork awesome I’m glad I kept looking if anyone ever wants to steal my boat here’s the number
What mods do you have on the boat? When's the next time you're taking your wife to dinner?
Bdog
Twin Cities, MN
AR195
Ha! Right now just seadek, an onboard tender and a Stoltz roller, only 20 hours though!
