jemorgan3
- LS
We have officially outgrown our 2015 242 Limited S and are considering selling it to upgrade to a 27’.
It has approximately 128 hours and is in great condition. Has been stored inside and covered if it is not in use. Seadek is 1 year old, has upgraded skar 6.5” speakers, lectrotab trim tabs, dual batteries, additional fuse panel/power distribution blocks under the helm powered with 0/1 gauge tinned wire to support any amplifier you want to install, two anchors, 1 year old Bimini made of heavy duty sundura in grey (goes with the suede grey hull much better than the black), thrust vectors, 6 month old steering cables. Trailer has guide poles with covers, a stoltz bow roller, Goodyear endurance tires with less than 500mi on alloy wheels and new pads/calipers this last spring.
Boat is not perfect, there are a few scratches here and there and I think the P.O. had beached it a few times so there are a couple scuffs on the hull, but nothing I have ever been concerned with. There are no rips or open seams on the interior, some very light staining from normal use. The tower has a few chipped spots and lots of bugs from trailering. Engines have been maintained exceptionally well, amsoil and oversized oil filters every spring. Batteries stay on a trickle charger when not in the boat.
Previous owner used it in salt water, we have only used it in fresh water. P.o. Was very good at using salt away and treating the boat for salt and stored it on a rack inside when not in use. Although the anodes could use replacing, they are still good. Both pumps have been disassembled for inspection and non of the bolts were frozen. I have two new jet pump housings that will go with the boat. I was going to replace both impellers and housings as preventative maintenance this fall. Have not purchased impellers yet. Boat will still do 50 with 4 adults and full fuel and has no cavitation on acceleration.
Located in the Louisville Ky area, can water test on Patoka lake/ Green River lake/Taylorsville Lake.
Clear title for both boat and trailer in hand, and I will personally transport the boat for a negotiated fee within 500 miles.
$48k
Due to the lower prices of plywood, not accepting trades for lumber at this time.
Please email with any questions @ jemorgan3@aol.com
$48,000
$48k
$48,000
