hatrik8
- LS
I've been looking for a good deal on a jet boat and I came across a 2001 LS2000 near me that I couldn't pass up.
I bought it knowing the port side engine would not turn over. Otherwise it's in pretty decent shape. The previous owner said it ran last year and when he went to take it out this year he couldn't get the engine to start. He thinks he didn't winterize it properly. He had a brand new ski boat in his driveway so I assume he didn't want to be bothered messing with the old yamaha.
I've checked the compression on the starboard engine and all 3 cylinders are right about 120.
I hooked up the hose to the engine flush and I was able to fire that engine up. The idle seems a little rough, if I increase the throttle it smooths out, but if I increase it too much it dies. So at least it has compression.....
I'm planning on pulling the port engine and tearing into it. Any tips/tricks/gotchas? What should I disassemble in the boat before removing it?
On my old yamaha jetski I basically would pull the exhaust first and then pull the engine out of the hull.
