skywalker13
- Jetcraft
- LS
Hello, new guy to the forum here (and pretty new to boating as well) and I’m hoping to get some info on a repair. I’ve searched the forum and internet but still having a hard time finding answers.
I have acquired a LS2000 from a close friend that has a pretty large hole in the hull. It’s definitely through the fiberglass and looks like it’s broke through some wood (type of OSB maybe?) on the inside too. Not sure if there’s a space between the two or if the fiberglass actually sits directly on the wood. Anyways, my questions are: does that wood need replaced/repaired? What’s the best way to repair the wood (replace whole board or cut out a clean hole and “plug” it with new wood/epoxy)? What’s the best way to get to the inside of the boat to fix the wood? Once wood is repaired, would I just layer fiberglass from the outside or both inside and out? Or would I repair inside of fiberglass first and then the wood?
I guess to put it simply, what is the best way to make this repair?
Im familiar on working with fiberglass. Just newer to boats and this type of repair. Basically, I would like confirmation so I can attempt this with some confidence that it’s being done correctly and that I have the right idea/not skipping any steps.
I’m looking to attempt this before going to an actual shop or selling it with the damage so please don’t just tell me to take it in somewhere.
Thank you all for any insight anyone might be able to give me. I appreciate it!
