Coryd
- Englewood, FL
Hey guys, maybe I'm missing something but do any of you pull the pumps and impeller shafts to lubricate the shaft splines as part of regular maintenance? I searched through the forums and couldn't find anything about it, aside from those who have replaced impellers. I have done all the maintenance on the boat myself up to this point (2018 AR210 with 150 hrs) per the checklist in the owner's manual. I'm having my bimini top (canvas torn, frame bent) and display screen (delaminating) replaced under warranty and the service advisor asked if I've been doing my own maintenance. I told him what I have done up to this point, according to the manual, and he asked if I had lubricated the bearing housing and shaft splines at 100 hrs. I said I did shoot some grease into the intermediate housing, via zerks behind the engines, but was a bit confused on where lubricating the shaft splines was stated on the maintenance checklist. He said the only way to lubricate this is to remove the pumps and pull the shafts out, which they charge $120 to do. I don't have access to a service manual so not sure if it's listed there but with all the knowledge in this group, I figured someone would know if this is actually required maintenance or the dealer just trying to squeeze $120 out of me. Thanks in advance.
