Maintenance due light reset
KADay
My AR 210 had maintenance at the beginning of the season. I bought it new in 2019 and have always had the marina, where it's stored, perform the general maintenance service. Today the "port engine maintenance due" light came on. About an hour later the "starboard engine maintenance due" light came on. This light has never came on before, so I'm assuming the marina normally resets it when they service it. I haven't taken it out very much this summer, so it's not due again for maintenance. I'm assuming it's a glitch or they just failed to reset it when they serviced it.
It's probably unrelated, but I did suck up some debris in the port engine an hour or so before these alerts appeared. It's was cleared out and running great when the light came on.
Like most, it's touchscreen and has the options for "next" or "quit" beside the maintenance light to stop the beepIng and clear the screen. The touchscreen has always worked just fine, but today neither next or quit worked. The beeping just continued all afternoon. Fun times! ?‍
I've tried researching how to reset the maintenance due light, but I'm not sure that I can even get around this alert screen to find the reset, since neither option will clear the alert. Has anyone had this happen or have any thoughts on how to fix this? Thanks in advance!
you should be able to silence the alarm although it will keep coming back until you reset it in the connext which you can do yourself. You probably hit a mark like 100 hours which sets it off.
