WREKS
- Port Saint Lucie, Florida
- SX
I found a corrosion channel in cylinder head on exhaust side of Cylinder#1. Purchasing a new head was not an option. Trying to repair it was. This is what I did: Drilled deeper into the corrosion channel to make a better anchor for the patch (like a root canal only on an engine head); Packed it with JB Marine Weld; braced the patch with a wedge of aluminum; Reinstalled head. So far I have only tested the patch on the hose at numerous 10 minute no-wake rpm, and 1 brief on the water acceleration to plane. So far, there is no milky oil, so I am fairly sure I found the problem; just not sure of the solution; Here are the pics:
