Mike Byrd
- X
I installed a Wet Sounds single voice coil 10" free air sub in my 2014 212X. This is a 2 ohm sub which is 600w max or 300w RMS. I also installed a Clarion Class D mono amp to drive it. It is the XC2110 and is supposed to be 2 ohm stable at 300w RMS. This amp blew up not long after I installed it. The fuse was blown and as soon as I replaced it, the new fuse would immediately blow. I figured I bought a lemon amp, so I bought another one and installed it. It blew up the same way. Are there any audio experts that can tell me the reason why these amps are not surviving? Is the power cable and ground cable size a reason this is happening? The sub is SVC, so it cannot be hooked up incorrectly. Do you think these amps are not really 2 ohm stable? I am trying to figure out what to do. Should I buy a 4 ohm 10" sub, or try another amp with the 2 ohm sub?
