Mooring cover question
rcpd34
MD
I just scored a brand new Yamaha mooring cover to $250! New in damaged box supposedly complete. Not my first choice in color, but for better than half price, I'm not complaining! No instructions either. My question is the poles are shorter than the factory transport cover poles I had been using. Are the OEM poles 2 piece? If so, I may be missing the lower halfs. Can anyone advise or explain how it works?
Thanks!
itsdgm
I think that you're right about the poles being "collapsible". I don't have a set like that, but I do remember other guys mentioning that. Sounds like a bargain at $250. Good find.
RightStuff
Twin Cities, Minnesota
Moomba
Yep the poles on the Yamaha mooring covers are collapsible. Each of mine have 2 pieces and the bottoms have a round base, maybe 4" wide, with some rubber feet, and the other end has the straps connected.
ScarabMike
Green Cove Springs, FL
On my old Sea Ray they were collapsible. Here is a tip, when you find the right height that gets you a nice not too tight fit, mark the pole with a permanent marker. That way it always perfect, and it helps when your installing it alone.
rcpd34
MD
I figured it out. One of the poles is missing a rubber foot. Hopefully I can steal it off the old pole.
