Captain Nik
- Scarab
- 165 ID
I would like to mount a chartplotter on the left side of the dashboard of my 2018 Scarab 165. The fiberglass area that contains the Information Center Gauges is sealed. I am looking for advice on how to remove the gauges so that I can put nuts on the bolts need to attach the chartplotter.
The gauges have hex nuts visible from the drivers position. When I attempted to loosen a hex bolt, it did not loosen. Out of concern of breaking the nuts off, I thought I would ask others how to disassemble the dash. Are the hex bolts for decoration only or do they need to be removed to take the gauges off the dashboard?
Also, the 12-volt receptacle does not work. I am hoping that once I can get the gauges off I will be able to troubleshoot the receptacle. Maybe someone knows where the fuse is for this receptacle on a 2018 165 ID.
thanks for the help,
