wajetter
My starboard engine (2006 AR230 HO) seems to be misfiring. When sparkplug #4 is disconnected, it smooths out the engine. Removal of other spark plugs one by one has very little effect - just a slight tone change. It seems that the least tone change is spark #2. Removing #2 is not noticeable, until re-connecting it.
I did some research and it seems like one of the main culprits could be the ECU keeping an injector stuck open. However, it is not clear if the main reason of the ECU issue is water intrusion. It appears mine has absolutely no water intrusion (see photo).
I opened the portside ECU box as well and it is also dry, to my relief. Tomorrow, I will swap the ECU from portside and see if it helps.
Should I look for wet spark plug after idling? Any other tips from experts?
Unfortunately, I have trouble connecting YDS to either of my engines. I think there is a misconfiguration to my Windows 10 Pro somehow. I heard there was a way to run some tests and hear injector clicks.
Video: IMG_4687
Video: IMG_4687
