betterwhenitswetter
- DFW, TX
UPDATE:
I posted in another thread about water/fluid in the engine, turns out its actually fuel in the engine b/c water got in the ECU and has caused havoc to the system, the water got there b/c my brother left the flush valve cap open (waverunner not boat) and water found its way into the ECU box, new ECU and wiring harness and 1 switch and 1 relay, about $2,000 dollars later (I bought 4 new injectors) so total of $2,600
thread here, https://jetboaters.net/threads/mr1-engine-help-cylinder-3-has-water.10138/
Moral of the story check you Environmental box first for water. I will post pics when I can.
MR-1 ECU (I have a OEM NEW ECU) during the swap, is it possible to add the hours from the old ECU to the new ECU?
I have Yamaha YDS diagnosis Software & DB 1.33v, I can view all data current old ECU data but not sure how to input new info into the new ECU.
or do I need a dealer to do add the hours?
