MOA_Chaser
- Chicora, PA
- SX
Changing the oil on my boat today, the port side went fine without incident. I switched over to starboard, fired up the engine and turned on the hose. After a while the water came from the exhaust like it should. But after a while I noticed the RPMs going up, and I noticed that the temperature warning light was on. Steam was coming out of the pissers, but no water. I threaded weedeater line down through the pee holes and it went several feet in as usual. Started the engine back up, and still have the same trouble.
What else should I be looking for??
