cybuch
- Gilbert, az
I could really use some help from someone who knows more than me. Here is the story:
I have a rebuilt MR1 SBT Engine. I installed it, broke it in, and it runs great. However, when I first start it and warm it up and go WOT, the oil pressure goes up to ~60 psi. Sounds normal, right. Here is where it gets strange, over the next 10 minutes at WOT, the oil pressure gradually drops to 30 psi. It seems to stabilize at 30 psi, but I think that is too low as my other engine hits ~65 and stays there. If I stop for about 10 minutes and start it back up, she is right back at 60 PSI at WOT, but drops. I called tech support at SBT and they said, these engines run at low PSI.
Here is what I have tried so far:
Pulled oil tank, took it apart and check the screen in there, all clear.
Pulled oil pump, installed a brand new one, did find 3 small rubber pieces in that screen (no idea where they came from)
Changed oil filter and used 10W40
Dropped oil pan, all clear in there
After all this, I still have the same issue with the oil pressure dropping.
I did put it on the hose today and warmed it up, when I go hi revs and look in the oil tank, the oil starts churning and spitting up out of the filler hole (not a lot, just spits out droplets). It also gets frothy but not milky, just aerated. Tested my other engine the same way and the oil stays smooth and it doesn't spit back out the filler hole. I am thinking the issue with the oil pressure dropping is due to the oil getting frothy, but I have no idea where to go next.
I do have a Yamaha waverunner I can rob parts from. Was thinking of swapping the oil tank with the waverunner.
Any help is greatly appreciated.
