biffdotorg
- Pelican Rapids, MN
- Limited S
The above recommendations on a charger are great. Noco and ProMariner are awesome products. But skip the word trickle or maintainer, and use the ones suggested that are a minimum of 10-12a per bank. Trickle/maintainers are for long term storage. And many of these true chargers will double as a 2a maintainer in the off season.
If you have a need for a charger elsewhere, you can use a standard battery charger, if you think you will only need it this one time to get them back to life. If running the electronics stock, you may be fine without an onboard charger. But after owning a two bank system, the convenience is so nice to just plug a cord into the side of the boat.
Good luck
Good luck
