AZ Native
- Phoenix, Arizona 85044
- Limited S
After researching threads on solar charging I had trouble with a solution for dual batteries, so I thought I would post my solution I rigged up this weekend. I chose a 100 watt Monocrystalline solar panel and built a frame to mount it on using 2x4 pressure treated wood and a Rural Power Systems adjustable mounting kit. The solar panel feeds a Renogy 10 Amp PWM Dual Battery Charge Controller and the extension cables from the panel to the controller are 20Ft 10AWG MC4 Adpator cables. The MC4 connectors make great water proof connections. For the connections from the controller to the batteries I purchased WindyNation 8AWG stranded cable which came with the necessary terminals for a clean installation.
I learned two lessons during the installation. First 10AWG cable is plenty for this application and easier to fit into the terminals on the Renogy controller which is designed for 10 AWG. Second Solar Panels do have a Positive and Negative line feeding the controller. I hooked it up backwards and the controller indicated I had fully charged batteries (slow flashing lights). When I figured out what I did wrong then controller gave me steady lights on both batteries indicating they were charging properly. The controller was the cheapest component of my solution, but it's a perfect solution for charging two batteries simultaneously. It's programmable and includes an on board temp sensor that adjusts the charging current when it gets really hot to protect the batteries. That matters here in sunny Arizona.
Here are some pictures of the final solution:
