biglar155
- Fredonia, WI
- SX
I'm mid-job at the moment but came back to the house for lunch and to let the boys mow the lawn. Figured I'd post the work so far:
So after a couple weeks of measuring, fretting, holding things in place, measuring, and fretting some more, I did the deed and started drilling holes in my boat.
I put some blue painters tape in place and with extra hands from the boys, we determined that this location seemed optimal.
Earlier in the week I had prepped a template for marking the holes:
The template also has a "stupid" side just in case:
Drilled two holes for the first (Starboard Side) tab so that I can hold in place and test. (I'd rather fill two holes than 18.)
Drilling was accomplished by STARTING with a counter-sink (gotta get the pointy kind - I'll post a pic as this thread continues), then drilling the correct-size hole. (Again, will post later, it's all written down on notes on the pad of paper sitting on the swim deck in storage).
With the holes drilled I ran the screws in to make sure I was good to go. On the first try, they were a little tight so I went up a size. After that they went in fine. (Yes this is a pic of the port side taken later. Back off man. Back off. )
To mount the tabs, I wound up having to remove my boat buckles to give them enough room to swing down out of the way. I'll still need to use an offset screwdriver to get them all in. (Already in the tool box.)
Then I just had to finalize the position of the actuator mount and pop a quick hole.
With all said and done, the bracket on the trim tab just makes contact with the boat when fully retracted. This shall cause me no loss of sleep, but I might add 1/16" to the gap between the front of the tab and the "step" in the hull if I were to do it over.
With one tab installed, I wired it all up to the controller (held in my hand) and a jump pack to make sure we had good movement and no binding. All is well.
I repeated the measurements (and double-checking) on the port side and life is beautiful.
Other than the small difficulty they will give me getting the screws in, my boat buckles will not be an issue due to the extension bracket I installed when I got them. The purpose of the bracket is to make sure the strap comes straight out of the ratchet mechanism. They came from Boat Buckle. I think I had to buy them separately.
Point is, they give me plenty of clearance with the tabs retracted so I don't have to relocate the straps.
One thing you'll want to watch for: Don't put the actuator bracket so close to the tie-down eye that the tie-down hook rubs on the actuator.
With both tabs "hanging" by a few screws, I ran another test and was satisfied with the install. We packed up and headed home for lunch.
Best part: I arrived home to find the 5200 and 4200 I ordered had arrived while we were gone so I can complete the install today.
More info and photos to come - but I think that'll be the bulk of it.
On the electrical front, I plan to install a panel under the port-side aft seat. The spot there is big enough for a 14" X 11" panel with a little extra clearance.
Here's what I'm thinking so far:
The black outline is 14 x 11 and the blue dots represent the mounting screws for the panel.
Having the ACR after the main disconnect is what I want. When I say "off," I mean "off." I want all contacts open.
Thoughts or advice on layout? I'm still fiddling with this one.
