Judge
- Cape Coral, FL
- 275SD
Made decent progress tonight. After cutting the notches in both tabs for the lights, I got all of the holes drilled and countersunk. Then I ran a screw in each hole. The I vacuumed out the holes and wiped down the hull with alcohol.
I'm going to put 3/4" screws in the three holes out by the chines. I can feel something like insulation when I poke a rod in the holes. It is part of the hull that is enclosed and can't be seen from the inspection ports. The rest of the holes are wide open so I will use the recommended1 1/4" screws on those holes.
Tomorrow morning I'll break out the 5200... squirt some in the holes and cover the back of the mounting plate and mount the tabs. Then tomorrow evening I will get an extra set of hands and line up the actuators and get them mounted under the swim platform.
With any luck I can have the actuators mounted tomorrow night and then pull the wiring to the helm and cut the hole for the Controller on Friday and have everything wrapped up.
