tahmad575
- West Milford, New Jersey
- SX
Hello boat kings,
I recently swapped out both my ECU's and the boat has been running fine up until a couple days ago my starboard engine started to only rev to 6k rpms. Port engine is good runs smooth up to 9k rpms.
No smell of fuel on the starboard oil dipstick but I decided to purchase a cheap compression test kit off eBay for $20
Big mistake because it is completely useless
To my surprise when I pulled out the spark plugs 5 of them were missing the electrode tip and core! The 3 that are good and intact have proper gaps as well. all 8 spark plugs were changed at the beginning of the season with ngk cr9eix irridiums, Plugs were checked and all were good when I swapped out the ecu's last month.
I wonder what could have caused the tips to break? also a slight amount of oil was on the threads of some of the spark plugs as seen in the photos
Test results:
Starboard
#1 50psi broken plug
#2 45psi good gap
#3 30psi broken plug
#4 50psi good gap
Port:
#2 50psi broken plug
#3 125psi good gap
#4 55psi broken plug
These are obviously not accurate because you could hear the compression tester leaking where the gauge hooks onto the hose with each crank. On port #3 ALOT of water was spraying out of the compression tester tube where it connects to the gauge..wonder where the water came into the #3 cylinder from ?
Engines were cold and throttles we're at full open, someone in a previous thread said his numbers didn't vary significantly from cold or hot readings but regardless I think this was a completely inaccurate test because the gauge and connection that came with it are trash
As for the plugs ...it's a mystery. The boat was running fine two days ago on the Hudson River except for the starboard engine which only revved to 6k rpm about 5 minutes into my voyage. I decided to leave it at 5k rpm and use the port at 8k rpm, that's how I cruised for about an hour, no changes in rpms or performance really. Just don't know how my port could have performed so well with 3 broken plugs inside the engine..must have happened after? I litterally just winched it onto to the trailer and drove to my warehouse and then did this test..unless they broke during the drive?
Test results:
Starboard
#2 45psi good gap
#4 50psi good gap
Port:
#3 125psi good gap
