andyak
If you followed my last thread - Starboard engine was completely rebuilt.
Reused parts on engine:
stator
sensors
gear output
I had her out this week and after about 4 hours on the lake we were about to start some water sports when the same starboard engine shut off and would not restart. cranked fine -no fireup
after getting her back on trailer using one engine (I clamped the line to water in when coming in on only port engine, but too late - I got some water up into the starboard engine)
- the starter was fried - luckily I had a spare.
- pulled plugs and cranked out as much water as I could
- compression between 180 and 210 with some moisture still around some cylinders ... so at least lower end is still fine!
- put in new plugs, and replaced fuel pump
Current problem: No Spark whatsoever, after running for half a day
-the only recent mod was install of dragonfly gps/fishfinder - I did drill some holes for bracket up by windshield on right of the dash - hopefully no wires are routed tight up to along the top.
My current options I am considering:
Swap ECMs to rule that out
Lift engine up and swap out Stator with a spare - and take off oil pan to dump all oil if any water got in.
Does anyone have any other ideas on lack of any spark after half a day running fine?
I really did not want another project like this mid summer
stator
sensors
gear output
