DBamaC
- Hoover, Al
- AR192
In working through everything on our new 192, I have found that my navigation and anchor light are not working. It's under warranty, but I hate to drag it in for something that is probably so minor.
With the battery on, you can press on the courtesy light switch and the navigation switch (both ways) and you get nothing. The horn does work.
I checked the anchor light bulb and the filament is in tact (I did not check the nav light bulb yet...brain fart at the time). The switches don't even light, but the circuit breakers are not popped so I assume the are not getting any power. I checked the 20 amp fuse adjacent to the battery that I assumed was the accessories fuse even thought I was thinking that if it was blown the horn wouldn't work. It is also in tact.
I'll probably (after checking the nav light bulb) dig into the dash next, but thought I'd see if anyone had any other ideas.
Thanks in advance!
Thanks in advance!
