Need Advice for Removing Lanyard Killswitch on 2008 232 Limited
Gonzo890
Limited
Starboard engine is cranking but not turning over. I believe the problem is the lanyard engine killswitch (after swapping spark plugs). I’m having trouble removing the switch. Went to remove the throttle to access it but 2 of the screws holding the throttle in place are completely stripped out. Is there any other way to replace the Lanyard Killswitch without removing entire panel?
Babin Farms
Lower Alabama
You should be able to get to it from the fire extinguisher hole.
