- Corinth, TX (DFW)
I would ask if there's a particular reason he thinks the wear rings, in our boats people don't have to normally change them but with the skis it seems like I always here people replacing them, (sidenote, I've got a friend with a seadoo switch and no dealer in his area, he had cavitation, took it to the local marina, they gladly replaced the wear rings but didn't say a word about the impellers which were unbelievably marred, now he's changing the impellers)
When you look up from underneath you can see the impellers and where they spin, if it's all chewed up, maybe there's a problem,
it's not uncommon for the wear rings to have slight grooves that you could feel with your fingernail but anything larger may be a concern,
also a jetski shop can help with reading hours or changing wear rings and impellers probably for a lot less than a dealer,
if your at full stop, put the throttles full forward, you get pushed back in your seat, in less than 5 seconds your on plane and you top out above 40mph I wouldn't worry about it,
