David Martin
- Punta Gorda
- SX
Hello
I got an sbt engine last year with 45 hrs on it. I know a real mistake. I tried to get 2 for my boat but they couldn't get me another good one last year so I built one from yamaha. But the sbt 1.8 ho all of the sudden popped a low oil pressure light . Runs 7400 rpm never misses a beat. Tested the oil pressure switch and it's good. Pulled the pump and there is some scarring on it but not gouging. Looks as if it should pump ok. Took compressed air and pulled pressure switch out and blew through engine. Reinstalled pump new oil filter and it went to 60 psi. As it warmed up it dropped to 21 on idle and 40 on full throttle. SBT IS A JOKE . I'm thinking bad tolerances on bearings. The warmer it gets the lower the oil drops. Anyone have another idea I might be missing ?
Sorry for the stupid question.............what oil pressure is the 1.8 supposed to have?? Most all pressures drop as the engine warms up 40psi is a good pressure.... JMO...... I'm not near my service manual so I'm not sure at what pressure the sensor trips at. 40psi should have good flow to all parts!! is it tripping alarm at 40psi?
