Jrlmlf
I have a 2019 ar240 and starboard engine will not start. Took it out all day about a month ago and had no issues. Came flushed engines. 3 weeks later went to go out again and port engine fired up no issue and starboard engine did nothing. I have tested all the kill switches and they are good. If I jump the starter relay the engine will turn over. I changed the starter relay 3 times and and still same issue. I did move it over to the port engine and started with no problem. Testing the leads to the relay I get power to the relay when I turn the key, but no power to the relay side that goes to the Starter. I have switched ECU, ignition, kill switches with no luck. Any suggestions?
